Author Topic: Wheels suspension  (Read 1983 times)
Offline mikey_magic
Wheels suspension
« on: 20 September 2012, 22:45 »
Hi guys
Just fitted new wheels 16x8 with 15mm spacers but the n/s/f wheel is sticking out fever then the o/s/f and ideas what the problem an how I can resolve the issue??????
Offline tweed
Re: Wheels suspension
« Reply #1 on: 20 September 2012, 23:11 »
You put your suspension on?
Offline tweed
« Reply #2 on: 20 September 2012, 23:12 »
It's either your camber is set up different each side, or the wheel et is different?
Are the wheels new or used?
Offline mikey_magic
« Reply #3 on: 21 September 2012, 08:20 »
The wheels are new??
Suspension not on yet...
The spacers i have put on all different hub but still the same.....
Offline tweed
« Reply #4 on: 21 September 2012, 10:47 »
Well it's possible the who ever sent your wheels out have sent one with a different et. Take off and measure them.
I still think its more likely to be your camber.
Offline VR6_Wherry
« Reply #5 on: 21 September 2012, 11:09 »
What wheels? Sizes and ET? Is it possible you have staggered wheels and put one on the front?
If not i would say get the suspension on and then get the camber and tracking sorted.
Offline mikey_magic
« Reply #6 on: 21 September 2012, 22:42 »
Wheels dare dr-b 16x8 et25 with 15mm spacers to clear the front brake clearance, from rimstyle doesn't matter what wheel I put on the n/s/f it sticks out more then the others...
If I change the suspension is this really going to help???????
Offline tweed
« Reply #7 on: 22 September 2012, 00:00 »
Two bolts that join hub and shock/coilover together also adjust the camber.
Can easy get it wrong.
Loosen them off and push the top of wheel all the way in on both sides. Then tighten up obivsly.
I have to do this to get even tyre wear.
Offline hobnobbob
« Reply #8 on: 22 September 2012, 16:08 »
might even be the spacers! take the spacers off and then put the wheels on. see if one of the spacers is the wrong size.
