Author Topic: Strange noise from inside the car.please help me it's driving me crazy!  (Read 2004 times)
Offline Gmanx1
  • Anniversary 1356
Hi all.
I was wondering if anyone could shed some light on the slight problem I have.
Basically when I turn my heater blowers on I get a strange noise coming from what seems to be behind the glove box,the noise will only happen when I have my AC running. If I press the Econ button the noise stops! Even though my air blower is still running.
The noise sounds like air is escaping from something.
Have any of you had anything like this before?
Any help will be great lads cheers  :cool:
Black magic TDI ANNIVERSARY
Offline Steve_PD
Sounds like the air circulation motor has failed.
Sounds like something gargling?
Offline james2
  • No scammers please.
Leave you air con off ,use econ mode and get good mpg. Mines been off for 4 years.  :smug:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Gmanx1
  • Anniversary 1356
Cheers lads,I could leave the air con off but I like to be cool in the heat. Lol
It's more of a noise as if air is Beeing replaced under pressure,almost like the sound when u let an air bed down.
Offline harlemex
try replacing your pollen filter
Offline Gmanx1
  • Anniversary 1356
Cheers buddy,does the pollen filter not filter none AC air?
Offline harlemex
when your air con is on the blowers still have to suck the air past the filter. However your pump might be tired  :undecided:
Offline rio_gti
my gf polo done this on the first day she had it.... but the next day it went..... sorry i was no help  :rolleyes:
Offline Gmanx1
  • Anniversary 1356
Quick update.
I replaced the pollen filter and the fault is still present. I have discovered that the noise will only occur when sat in traffic for a few minutes,once I drive off again the noise goes within a few seconds!
Anymore thoughts lads?
Offline Spacekid2009
Got exact same problem, someone on here must know a permanent fix. If it was the blower, are they a mission to replace?
