Author Topic: oil light problem  (Read 1422 times)
Offline Nebbo
oil light problem
« on: 08 July 2005, 20:21 »
hey folks - got a new problem, the oil light is now flashing in my mk2 as i drive and not only does it flash there is some buzzing noise coming from like inside the dash! ne clues??? hoped it was just electrical but i doubt it is.  Shed some light
Cheers Ben
Offline Deefadog
  • Mk2 16V (November 89)
Re: oil light problem
« Reply #1 on: 08 July 2005, 20:29 »
Thats the oil buzzer!
Check the level of oil, if ok do an oil and filter change! - oil - VAG syta silver (gsf) , genuine vw oil filter! (VAG)
Also check the plastic bit between the dip stick and the metal tube the dip stick goes in (don't know techancal name) :)
These can break and give a false oil level!
Offline Nebbo
« Reply #2 on: 08 July 2005, 20:33 »
cheers mate, oil level does seem to b fine (bit blackish tho) what do you mean when u say
Quote
cheers matey boy
diagnosis-dub
« Reply #3 on: 08 July 2005, 20:59 »
The oil light and buzzer on mean you shouldn't be driving the car, its the warning for low oil pressure, I would be inclined to not drive the car and get the oil pressure checked myself to make sure everything is ok.
The electrics in the dash sometimes go pete tong but better to be safe then sorry.
Deefadog means that you should use quantum silver oil and a genuine VAG oil filter.
Offline hockeylad72
« Reply #4 on: 11 July 2005, 22:10 »
sorry to hear about you problem check out these threads may be off some help
http://www.golfgtiforum.co.uk/index.php?topic=19035.0
http://www.golfgtiforum.co.uk/index.php?topic=18278.0
hope its not serious
cheers
Davie
Offline ...joe
« Reply #5 on: 12 July 2005, 11:30 »
also you can get the genuine filter from gsf but you have to ask for it, they are only a few quid. cheaper than halfords and you know your getting the best one!
check for leaks etc as this can drop the pressure. there are two pressure switches. one is a low pressure one which is activated when you start the car, the other is a higher pressure one and should read 2 bar at 2000 revs and over  so its more likely this one thats making the noise/lights come on. but a good oil flush/change should cure it.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Mart8V
  • I really should know better by now.....
« Reply #6 on: 12 July 2005, 20:06 »
Have had the same problem of late.  LIght only on for a second before going out, but have recently done a full service with Synta silver and genuine filter.  Am I correct in thinking that the engine takes 4litrs with a new filter?  If not it will need a little topping up, but level on dipstick seems OK.
BTW- spoke to a VW guy near me who said that if you have changed the speedo the blue circuit piece sometimes gets worn with time and this can cause the buzzer to come on.  Anyone else come across this?
