Author Topic: Up hill limp mode/slow!!!  (Read 3410 times)
Offline Wilts
« on: 20 September 2012, 21:12 »
Heys guys its a hard one to explain but il do my best, basicly when i go up a slight hill around 30-40mph its like the car slows rite down and struggles so im normally in 4th gear so i have to change down its happend afew times and its done it 2nd gear about 20mph its strange its a 1.8T 20v engine hope some-one can shed some light??
Vw is the way forward its took me many years to realise this!!
Offline Chris.
Re: Up hill limp mode/slow!!!
« Reply #1 on: 20 September 2012, 21:57 »
Fault codes?  Sounds like a pressure drop or maybe a over boost issue.
Click For Build Thread
Offline Wilts
« Reply #2 on: 21 September 2012, 08:47 »
Ok il get a code reader 2nite and put codes up and go from there, thanks for your reply.
Offline Wilts
« Reply #3 on: 21 September 2012, 21:16 »
The code is 00575 ive looked on google but it sounds like it could be anything, manifol absolute pressure but does any-one have any simple ways for me to look out for? Many thanks :smiley:
Offline Chris.
« Reply #4 on: 22 September 2012, 13:13 »
What engine code is yours?
Offline Wilts
« Reply #5 on: 22 September 2012, 13:17 »
Aum i think il go check
Offline Wilts
« Reply #6 on: 22 September 2012, 13:19 »
Scrap that its a AGU engine
Offline Wilts
« Reply #7 on: 23 September 2012, 08:12 »
Can anyone shed any light on this plaese and what i should be looking for?
Offline Chris.
« Reply #8 on: 23 September 2012, 18:10 »
AGU limp modes are typically load based where engine cant match the load wanted by ECU, or vice versa.
Have you checked all the pipework and done logs on the N75 valve and MAF sensor to see whats going on?
Offline Wilts
« Reply #9 on: 23 September 2012, 18:37 »
Thanks for ya help chris, all ive done is put code reader on and came up with the above code, i will check hoses during the week when i have more time it does it when its hot i cant say ive noticed it when cold.
