Author Topic: Intermittent starting problem  (Read 1547 times)
Offline CM690
  • Golf MK4
« on: 19 September 2012, 19:54 »
I've posted about this a few months ago but my car has developed an intermittent starting problem. When I first got the car the temperature gauge was playing up, would take a good 20-30mins to get up to temperature then the faster I went the colder the engine got so I replaced the temperature sensor with a eurocarparts one and the gauge is fixed it just takes a long time for it to get up to temperature but once it's at 90 it will stay there.
The car starts fine most of the time but occasionally it will turn over for ages, kick in, splutter and the engine struggles and the revs are jumping about even as high as 3k-4k rpm then cuts out and I have noticed that sometimes in traffic it won't have a consistent idle it will bob about around 700-900rpm.
Weirdly though once it starts its absolutely fine and drives perfectly!
so far I've changed the coolant temperature sensor (though I don't think that was causing it anyway) and changed the crank position sensor because I was getting an error from my little handheld code reader device saying it was faulty though I've recently learnt that the code is given if the car turns over for too long anyway! :cry:
Any ideas at all? I will most probably be shifting this and looking at an audi a3 if I can't cure it.
Will the thermostat cause these problems? I read on other forums just from googling the issues that it could cause issues but I can't see it myself.
Thanks for the help :cool:
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Intermittent starting problem
« Reply #1 on: 19 September 2012, 21:07 »
If it is ticking over for ages is it the spark plugs? Coil pack? Injectors? Got full vagcom to scan/log some of the blocks?  :undecided:
Offline CM690
  • Golf MK4
« Reply #2 on: 19 September 2012, 21:09 »
turning over? Well I've got a set of plugs but they are an absolute ball ache to fit because the inlet manifold goes right over the top of them so I'm waiting on my dad to sort that out. I'm praying that will cure it. Sadly I don't have full vagcom just one of those ebay specials handheld readers. How much are coil packs and injectors?
Offline scarr89
« Reply #3 on: 19 September 2012, 21:10 »
I am no expert. However, a coil pack maybe £80? Injectors perhaps similar?  :undecided:
Get one of the petrol heads to aid you  :lipsrsealed: :embarrassed:
Offline james2
  • No scammers please.
« Reply #4 on: 19 September 2012, 21:32 »
Change your themostat for a start.  :wink:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline CM690
  • Golf MK4
« Reply #5 on: 19 September 2012, 21:41 »
Is that an easy job to do myself? Should I get a gen one from VW or will a auto factors one be alright?
