Author Topic: steering wheel grinding  (Read 2298 times)
Offline joshstanvw
« on: 19 September 2012, 19:27 »
wondering if anyone can help. Over the last few days my steering wheel has developed a grinding noise and i have not a clue why its coming from just behind the steering wheel itself and is no harder to turn than usual
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
Offline Lewy
Re: steering wheel grinding
« Reply #1 on: 19 September 2012, 19:35 »
Check that nothing has got between the cowling and the wheel itself as that would create a scraping/grinding noise.
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 19 September 2012, 20:04 »
Theres a contact slip ring for the horn behind there,you need to pull the steering wheel off ,give it a clean off and apply a smear of copper slip ,job done  :wink:
Offline joshstanvw
« Reply #3 on: 19 September 2012, 20:08 »
thanks guys i will do that tomorrow and hope the annoying grind goes away
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 19 September 2012, 21:26 »
This, all three of my mk3's have have needed this doing at some point.
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 19 September 2012, 23:04 »
could be the suspension top mounts. mine groans & moans lol :evil:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline doom_bar
« Reply #6 on: 20 September 2012, 00:35 »
Sorry for the dumb question but an you confirm how you remove the steering wheel? Is it just a case of prising of the centre cover and undoing a centre nut? What about the airbag?
« Reply #7 on: 20 September 2012, 07:37 »
DO NOT PRISE THE AIRBAG OFF! Disconnect the battery and leave for 10minutes, then undo the two hex/ Allen key bolts on the rear of the wheel to remove the airbag. The yellow wiring connector on the back of it can be levererd gently from its hole with a small flat screwdriver. Now you can undo the centre retaining nut...
Offline philmar
« Reply #8 on: 20 September 2012, 08:49 »
 My Vento does the same. To save time, would it be worth trying to use an airline or one of those compressed air aerosols followed by some WD40 as lubrication ?
« Reply #9 on: 20 September 2012, 10:10 »
WD40 is too thin and only stops the noise very temporarily. Copper slip grease is ideal here.
