Author Topic: oil sump question  (Read 1704 times)
Offline 1.8t.jim
oil sump question
« on: 18 September 2012, 19:21 »
my friend and i have fitted my new sump and oil pump today, but we did it with a ratchet and socket set, but i have been told use a torque wrench, i havent tightened the bolts up much just hand tight then a quarter turn on all the bolts will this be ok ?? or will this not be ok and is likley mess up ?
Offline jamie1989
Re: oil sump question
« Reply #1 on: 18 September 2012, 19:23 »
Thats be cool mate, youl kill the threads over tightening them.
I did mine up using a alan key then nipped with a 10mm socket. Just makesure you got plenty of silicone sealant mate for a good seal.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline 1.8t.jim
« Reply #2 on: 18 September 2012, 19:26 »
thank god for that i thought ive messed it all up lol i havent tightened them up much, just hand tight then a quarter turn on all the bolts the same, used vw/audi sealant so hope it doesnt leak, how long does it take that sealant go off?
Offline Chris.
« Reply #3 on: 18 September 2012, 19:27 »
Usually a few hours, but for piece of mind, leave it overnight before sticking oil in.
Click For Build Thread
Offline jamie1989
« Reply #4 on: 18 September 2012, 19:30 »
I left mine for about 2 hours  :grin:
No leaks after a few weeks, You should wait longer really but it was warm that day too.
Offline 1.8t.jim
« Reply #5 on: 18 September 2012, 19:37 »
thats alright then, my car is out of action now untill i get my ko3s turbo so will be left standing for about 3/4 weeks without oil in, so that should sort it, just hope i put enough sealant on to seal it  :smiley: knowing me as soon as i put oil in, in a month it will leak  :drool: lol how much pressure does the sump take ?? or is it jut there to catch the oil like a reservoir ?
Offline Chris.
« Reply #6 on: 18 September 2012, 19:39 »
just there to catch it mate.
Offline 1.8t.jim
« Reply #7 on: 18 September 2012, 19:42 »
great stuff so it should be sealed and dont need worry about it leaking, if its only catching oil  :smiley: at least its got 3 weeks for the sealant to harden  :smiley:
Offline 1.8t.jim
« Reply #8 on: 18 September 2012, 19:53 »
the sump sealant i used was dirko, is this anygd and does it harden alright ??
Offline dan2252
« Reply #9 on: 18 September 2012, 22:48 »
Don't use to much either or the sealant will drop off into sump then get sucked up  blocking the oil pick up pipe
MK4 golf 1.8 turbo agu :)
