Author Topic: rough running until car warms up  (Read 941 times)
Offline Jasikasisback
« on: 18 September 2012, 10:14 »
judders and shakes when startedfrom cold. this seems less severe once i have warmedthe car up.any ideas? recently changed the small vacuum hoses on air intake. not helped much :(
Offline javalin
Re: rough running until car warms up
« Reply #1 on: 18 September 2012, 16:40 »
Common fault would be coolant temperature sensor (CTS)?  Does it come up to temp (90c)?  Could also be ignition related, plugs, leads or coil pack.
Has it been serviced recently?
Other things to check would be hoses for air leaks, clean the throttle body, etc.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
