Author Topic: problem with G60 / VR6 conversion....  (Read 737 times)
Offline simon_709
« on: 16 September 2012, 18:32 »
Right I got my new flywheel and clutch fitted today. When I got everything back together I went to pull away and the car wouldn't drive. I could lift the clutch fully while in gear and it wouldn't move :s. There is no bite point or any feeling what so ever. I took the gearbox off again and had a look to see if I had missed anything, and I noticed that I had 3 small metal round pieces left over that I got in the kit. From what i can see is that they slot in the flywheel as well as the clutch bolts. Does anyone know if these are necessary for the clutch to work? As I checked everything else and all was fitted correctly. Thanks in advance
My Golf GTi, RS4 reps 17", coilovers, tinted windows, De-cat and middle box removed with 3" oval back box, stage 1 Revo re map, G60 flywheel/VR6 clutch, HID kit, Forge 007p,
Offline GTi_James
Re: problem with G60 / VR6 conversion....
« Reply #1 on: 17 September 2012, 08:40 »
try putting the bits in that you didnt fit and see if that works?  :undecided:
