Author Topic: KO3 turbo blown, KO3-S fit?  (Read 1000 times)
Offline Bellend
« on: 16 September 2012, 14:23 »
Got a mate and his dad has a MK4 GTI 1.8T and was saying the turbo is blown. I haven't looked at the vehicle but aparrently the garage over the road said it was a write off but I doubt it, the garage is known to be lazy and pretty crap.
I have sourced a KO3-S just up the road and am wondering if this fits without worry?
Does it need to be mapped or anything or can I bolt it on and carry on?
Cheers.
Where all my moneys went.
Delta-Force
Re: KO3 turbo blown, KO3-S fit?
« Reply #1 on: 16 September 2012, 14:41 »
it will fit as they look the same just the 3s has more blades inside the turbo iirc if the cars mapped already it will fit and run and pull a bit harder , you might be able to push the turbo a bit more if you get the map ajusted though check for cracks on the hot / exhaust side they always go there because people dont let there cars cool after driving hard
Offline jamie1989
« Reply #2 on: 16 September 2012, 15:02 »
Remapped or not fit the K03s it will run fine anyhow.
No mods needed when fitting the k03s everything is the same fitment.
K03 has 12 blades, K03s has 8  :whistle:
Goodluck.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline dstv
« Reply #3 on: 16 September 2012, 16:02 »
I just had a ko3S fitted and its a straight forward enough job....but you do need a TIP as the KO3 TIP is attach to the turbo..
2000 GTI 1.8t AGU, neuspeed airfilter,Forge 007 dv, R-tech stage 1 remap, Silicone TIP,3" exhaust system, K03s turbo and a empty wallet.
Offline jamie1989
« Reply #4 on: 16 September 2012, 17:11 »
Good call. I would buy a silicone jobby off ebay.
Or just get one from local scrappy but makesure its not from a AGU or ARZ engine code as they run K03 turbo's and wont fit.
