Author Topic: can i just swap my clocks over with out any troble?  (Read 2942 times)
Offline Neg-1989
  • 1.8t agu stag 1map forge v008 www.derbydubs.co.uk
« on: 16 September 2012, 14:10 »
my rev counter had stopped working cany i just by some second hand clocks anf fit them with out any problems?
Delta-Force
Re: can i just swap my clocks over with out any troble?
« Reply #1 on: 16 September 2012, 14:42 »
no pal they will need codeing as part of the immo is in the clocks they will fit and work you just wont be able to start your car you need someone with vag tech ideally to recode them
Offline Neg-1989
« Reply #2 on: 16 September 2012, 15:44 »
is vag tech the same as vag com? and could i swap over the rev counter from one unit to the other?
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
« Reply #3 on: 16 September 2012, 15:55 »
As I understand it... if say you had a replacement set of clocks with the same mileage and knew the SKC for both the you could use VCDS, for mileage changes and/or SKC retrieval you need VAG Tacho also, for one off use these will be a costly option for you to invest in so best to find someone local who can do it for you?
EDIT: As regards changing the actual tacho instrument if both clusters were same ie VDO or motometer? I guess it could be possible but not sure how involved that would be not had them stripped down to have a look myself.
« Last Edit: 16 September 2012, 15:58 by Golf_GT_TDI »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 16 September 2012, 18:44 »
the clocks are one whole board so no you can't change just the rev counter.
You will need someone to pull the SKC (secret key code) from the new clocks to enable you to code your keys to the new clocks. If you have immo3 you will need the SKC from your clocks as well
Offline Neg-1989
« Reply #5 on: 16 September 2012, 22:31 »
how will i find the secret key code out for the new clocks? and how ill i know if i have immo3?
Offline Neg-1989
Re: can i just swap my clocks over with out any trouble?
« Reply #6 on: 16 September 2012, 22:53 »
Also if anyone could talk me through step by step how to fit code clocks and miles be amazing help.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 17 September 2012, 17:46 »
what year is your car mate? You will need VAG COM and VAG Tacho to do this
Offline Neg-1989
« Reply #8 on: 18 September 2012, 00:18 »
2000 my mates only got vag com
Offline rio_gti
« Reply #9 on: 18 September 2012, 10:40 »
If we told you where to find the secret key code it wouldn't be a secret anymore  :grin:
http://forums.vwvortex.com/showthread.php?3568883
http://forums.vwvortex.com/showthread.php?1921113
Should be all you need!!!
