Author Topic: Hot inlet manifold  (Read 2031 times)
Offline dub whore
Hot inlet manifold
« on: 16 September 2012, 11:31 »
I've recently put a new engine in and in the process deseamed my inlet mani and polished it. I dunno weather it's coinsidence or wot but now my inlet gets really hot which you all know ain't a good thing. And ideas?
Offline Chris#101
Re: Hot inlet manifold
« Reply #1 on: 16 September 2012, 11:37 »
When you polish something you remove all the pits (which makes that mirror effect?) that dispurse heat Which in turn attracts and holds alot of heat due to it not being able to escape aswell !
its hard to put into words  :grin: but I know what I mean
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« Reply #2 on: 16 September 2012, 11:37 »
This happened to me, I didn't clean or take it off, it just started getting really hot after driving it for a couple of mins. I replaced my maf with a new one, and it sorted the problem out!
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline dub whore
« Reply #3 on: 16 September 2012, 11:41 »
My maf is pretty new. I don't see how the maf can affect the temp of the inlet tho??   :huh:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 16 September 2012, 12:40 »
MAF controls the fuel. Fuel cools the mixture. If it runs lean due to a dodgy MAF, it runs hotter
Offline Prawny
  • R-tech power!!!
« Reply #5 on: 16 September 2012, 13:28 »
I think if the only thing you've changed is the polished inlet then that's where the issue lies.
The inlets are a textured finish for a reason, the textured surface has a greater surface area over which heat can dissipate away. polishing it reduces the surface area and it won't cope with heat that well.
That said, if you're inlet is getting ultra hot then you probably need a better intercooler setup or WMI. The inlet on my 300bhp 1.8T feels like an icy can of beer after a thrashing, it's actually freezing, even on a hot summers day!
Offline jamie1989
« Reply #6 on: 16 September 2012, 15:58 »
As above my THS intercooler keeps temps down all the time when thrashed  :cool:
It does get hot once stood still on idle though lol
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline dub whore
« Reply #7 on: 16 September 2012, 21:58 »
Yeh mine isnt hot all the time. My front mount does the job but when stood on idle it's too hot to touch!
Offline shaft69
« Reply #8 on: 17 September 2012, 10:06 »
If cars not moving intake temps be pretty hot no flow through cooler to cool it so thought temps be 60-70degrees if not higher. mine when driving are low 20's with wmi on seen 4degrees.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Prawny
  • R-tech power!!!
« Reply #9 on: 17 September 2012, 10:17 »
what does it matter how hot it gets on idle? on idle there is no airflow, and the bay gets red hot, plus heat conducting up from the engine, it's always going to get hot.
to find out if you have an issue, do a few hard pulls on boost, then pull over straight away and see how hot the manifold is then. if it's still red hot, then your intercooler is crap :)
IAT's of sub 10 degrees are not uncommon when using WMI :) even after a pull through the gears to 140mph on a hot day mine only peaked at 21 degrees!
