Author Topic: GTi 8v starting problems...  (Read 2010 times)
Offline lancs83
« on: 16 September 2012, 10:55 »
Hi - Ive replaced the lift pump, main fuel pump, accumulator, fuel relay etc etc. ~and tried 3 diffrent ECU's but I still cant get my GTi going   :cry:
The best it will do is start and run for a few minutes but die as soon as I try and rev it.
But now it wont even do that! it turns and starts and dies after a second. It does actually start then dies straight away. if I try and restart sometimes it dosent even turn over.
any suggestions?  Ive tried testing the earth's and it seems to be earthed fine. (rcker cover, gearbox etc) Thanks
Offline sparkplug
Re: GTi 8v starting problems...
« Reply #1 on: 16 September 2012, 12:23 »
is your fuel filter blocked
my hall sensor packed up & had similar symptoms
try this from memory,but check the Haynes manual....
undo the electrical plug on the dizzy , put a multi meter set on DC volts
across the outer 2 connections (on the lead NOT the dizzy)
turn the ignition on , it should show 5volts
if yes it's probably the hall sensor (i had to get mine from Bosch in Germany £94 ..IIRC)
if not the ign module is probably shagged
have a look in the haynes manual (green cover version)
« Last Edit: 16 September 2012, 12:25 by totalnuttah »
1986 GTI atlas grey
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #2 on: 16 September 2012, 13:00 »
Also check all the earths on the car - most ECU issues are due to bad earths..
For More Info Click To See;
Offline apie2004
« Reply #3 on: 17 September 2012, 11:32 »
I had a similar problem and one of the wires to the MAF had worn through
Offline lancs83
« Reply #4 on: 08 October 2012, 21:53 »
Got the car to start and run - engine warmed up and could take revs / drive the car etc. Drove it to the MOT station and they have had it about 2 weeks. Now they have got round to it and it wont start again! Got a spark but no go   :angry:
Offline Mr Blue
« Reply #5 on: 09 October 2012, 11:19 »
Tried the ignition moduel ontop of the ecu? You still get spark when they are blown.
Offline lancs83
« Reply #6 on: 09 October 2012, 13:58 »
Being thick but what is a MAF ? Thanks
Offline oakgreener
« Reply #7 on: 09 October 2012, 16:17 »
Mass Air Flow sensor. Fitted in the air intake
Offline lancs83
« Reply #8 on: 11 October 2012, 12:30 »
Ok thanks for the suggestions - will check these. I have a spare ignition module. How much are MAF sensors?
Thanks Luke
