Author Topic: Finally got lowered but  (Read 1338 times)
Offline spudboy6
  • Just like a golf ......
« on: 15 September 2012, 21:21 »
Fitted my 60/40 kit today and I run 14's and it completely slammed it ! I didn't think it woul get that low on a 60/40
And in the process I broke a rear bleed nipple and a brake pipe was about to burst but glad I caught them early !
Anyways done my 4wheel alighnment camber ect fitted new track road ends and now it drives like it was new !
The old springs were so dead when I pressed the piston in , it didn't even rebound out AT ALL !
Anyways happy man now but can see my 15's fitting under there now ???
Gavv8
Re: Finally got lowered but
« Reply #1 on: 15 September 2012, 21:26 »
15's are standard size on a GTi and mine is lowered 80/70 so you should be fine.
Offline eamonnism
« Reply #2 on: 15 September 2012, 21:56 »
I had mine dropped 120/100 on coilovers with 15s which fitted  fine. Slight tuck but no problems turning or anything so you'll be fine.  :wink:
Offline spudboy6
« Reply #3 on: 15 September 2012, 22:25 »
Sweet suppose I'm on 14's now , so when I fit 15's I'll be an inch off the ground higher and smaller profile in the arch every cloud .....
Looks and hand'els so good . But anything would compared to the old shocks , they where SHOCKING
LOL
Offline tweed
« Reply #4 on: 15 September 2012, 23:28 »
LOL
Your math is shocking  :laugh:
It won't be inch higher off the ground and top of tyre will be in the same place as the 14"
Offline Len
« Reply #5 on: 18 September 2012, 12:45 »
The overall wheel/tyre diameter should never change!
Bigger wheels will need lower profile ratio tryes.
There are Guides giving this information on here if you look!
www.sas.org.uk
www.the-ace.org.uk
