Author Topic: Best Spark Plugs?  (Read 16231 times)
Offline Jasikasisback
Re: Best Spark Plugs?
« Reply #30 on: 23 November 2012, 05:52 »
Beru are good as well. Which ones were you gonna get from eurocarparts?
Beru make quite a few spark plugs, so there is a range of suitable ones for the AAM.
NGK BUR5ET are pretty good plugs, so would assume they are more expensive than bottom range Beru.
i am not sure as i can't tell what type they are the three around 4 pounds of the three brands metioned. the ngk is out of stock so it is between the bosch for 3.59 or 3.96 or the beru for 4.44. the cheaper plugs like one of the three pronged beru  for 2.32 are out of stock as well . those are the candidates.dont know if tose ngk are the bur5et or not.
Offline tweed
« Reply #31 on: 23 November 2012, 06:38 »
They're out of stock for a good reason  :wink:
I get mine from eBay.
« Reply #32 on: 24 November 2012, 22:23 »
« Last Edit: 25 November 2012, 07:49 by Jasikasisback »
Offline drc12369
« Reply #33 on: 25 November 2012, 21:15 »
Ok so ive got NGK BUR6ET sparks coming in the post. What will i need to fit these and remove the old ones? mm sizes please, ive never done this before so reply like im an 8yr old retarded boy :laugh:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #34 on: 25 November 2012, 21:48 »
got  NGK BKR7E in mine (audi s3 engine for those who dont know) colder plug due to bigger power of the larger turbo
copper are best just dont last as long, does not matter to me tho as ill just change every 5k miles, they cost a couple quid each
Not no ordinary GTI....
www.mixcloud.com/kells/
« Reply #35 on: 02 December 2012, 22:07 »
finally ordered some. hope it will solve my rough idle and emissions problem!cant wait till wednesday!
Offline drc12369
« Reply #36 on: 03 December 2012, 07:53 »
Replaced mine yesterday for the first time. Put in NGK BUR6ET plugs in like 2 minutes. Lovely job. Only problem now is ive had the vw for just over a month and i think ive caught the bug now. I keep going from part to part wanting to replace everything  :smiley: ht leads next me thinks.
« Reply #37 on: 09 December 2012, 10:43 »
Ok will change plugs today. Haynes says to just remove leads by hand and other sources say you have to be super careful and use needle nose pliers.
A daunting task for me. I want to keep using the leads and havent got replacements yet
.any advice? I apologise if this is hijacking but thought it is quite relevant. :)
Offline tweed
« Reply #38 on: 09 December 2012, 12:29 »
Grap the lead at the base on spark plug and pull.
Man up lol and you don't need to tighten the new plugs up tight. Tight yes, but not super tight.
VW BUSH
« Reply #39 on: 09 December 2012, 12:43 »
+1
Nothing worse than getting a broken off or rounded plug out :whistle:
At least on an 8v you stand a chance :grin:
I'm running a set from my dads old Audi 1.8t, not the right plug but he has boxes of new ones that dont fit his new soot chucker how pikey is that :grin:
