Author Topic: Best Spark Plugs?  (Read 16208 times)
Offline itavaltalainen
Re: Best Spark Plugs?
« Reply #20 on: 18 November 2012, 18:12 »
Beru are good as well. Which ones were you gonna get from eurocarparts?
Beru make quite a few spark plugs, so there is a range of suitable ones for the AAM.
NGK BUR5ET are pretty good plugs, so would assume they are more expensive than bottom range Beru.
Offline Screech16v
  • MK3 20vt AGU
« Reply #21 on: 18 November 2012, 20:43 »
I allways go for bosch ,ngk or beru .in that order
Offline tweed
« Reply #22 on: 19 November 2012, 07:19 »
I use ngk b9egv for the kart engine and they are the bollox.
NGK all the way
Offline drc12369
« Reply #23 on: 19 November 2012, 08:51 »
So will 101-000-036AA NGK BUR6ET fit my 97 mk3 2.0 8v?
Offline tweed
« Reply #24 on: 19 November 2012, 11:10 »
Same plug as I use  :wink:
Offline drc12369
« Reply #25 on: 19 November 2012, 18:30 »
So is that a yes? The ebay seller says its not suitable?
« Reply #26 on: 19 November 2012, 21:02 »
97 GTI means you got a AGG or AKR engine..... for both BUR6ET are correct according to Haynes.
Offline drc12369
« Reply #27 on: 19 November 2012, 21:20 »
Its an AGG
Offline tweed
« Reply #28 on: 19 November 2012, 22:56 »
No I bought the wrong ones for my car then put them in anyway  :rolleyes:
« Reply #29 on: 19 November 2012, 23:23 »
BUR6ET are a match for AGG :)
Even www.ngkpartfinder.co.uk confirms - specifically lists AGG (and all other Euro-Mk3 2.0 8V engines).
