Author Topic: Does any one no about clio clutches  (Read 2233 times)
Offline ian007miles
« on: 15 September 2012, 11:37 »
I've just had a new clutch fitted in my mrs 51 plate Clio 12 16v and the bitting point on the peddle feels realy high does anyone no wot could be the reason. I was thinking stretched cable but any advise will be apritiated thnx Ian
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline Bellend
Re: Does any one no about clio clutches
« Reply #1 on: 15 September 2012, 11:42 »
I always put a new cable on with a clutch (if it's a clutched cable) seeing as they are cheap. Not really worth the hassle without as you're proving.
Euro car parts, £25 or £35 depending on how long the old one is. Stick in MIDMONTH30, get 30% off and happy days!
Where all my moneys went.
Offline Bellend
« Reply #2 on: 15 September 2012, 11:45 »
If there is an adjuster on it, you can try it but I'd still reccomend a new cable.
Offline Adam
« Reply #3 on: 15 September 2012, 17:57 »
I believe the 1.2 is hydro and is a strange system to bleed.
Down Hill From Here.
Offline Bellend
« Reply #4 on: 15 September 2012, 17:59 »
Some are some aren't.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #5 on: 15 September 2012, 18:28 »
Its probably where it should be, remember this is a new clutch, and not the old knackered one, give it a week to get used to it...
Thom
Offline Bellend
« Reply #6 on: 15 September 2012, 19:07 »
Thom
Surely it should be nearer the bottom though?
Unless it's auto adjust and slowly working in?
Offline Adam
« Reply #7 on: 15 September 2012, 21:15 »
Come to think of it. If it is the hydro box its the same as the box on a Nissan Micra and after doing that the clutch is high even after bleeding it properly.
Offline Thom89
« Reply #8 on: 15 September 2012, 21:15 »
Thom
Without any of us actually sitting in the car and trying said clutch, then a bit of common sense should come into play, shot clutches either slip, or have a biting thats on the floor... new clutches have a high biting point, and feel much lighter
Advising the OP to start changing things is simply poor advice, taking it back to the garage seems like a better idea, so they can check, and give a qualified opinion based on how the clutch behaves...
And dont call me surely :grin:
Thom
Offline danny_p
« Reply #9 on: 15 September 2012, 22:22 »
if it cabel clutch it may want loosening a littel.  if its hydro that just may be how they are.   both my passat and A4 felt like they had wierd clutch pedals but there just like that.  small littel girly cars tend to have fluffy light pedals
all the VW's have gone bar 1.
