Author Topic: 18s on a MK4 GTI T  (Read 3061 times)
Offline jblack
18s on a MK4 GTI T
« on: 05 October 2003, 23:31 »
Hello all,
Prob a stupid question but what effect will replacing the standard 16" wheels with 18"s have on 0-60 timings, acceleration etc? Will the speedo be out much?
Offline Rally_Chris
Re:18s on a MK4 GTI T
« Reply #1 on: 07 October 2003, 17:45 »
Normally you would put a lower profile tyre on an 18" rim for Golf fitment so the rolling radius would remain about the same as the 16" tyre - therefore there would be negligible effect on the performance speedo accuracy.
I can't remember the normal 18" tyre size that is commonly fitted to Mk4's but if you search on the net there are tyre sites where you can enter your existing tyre size (eg 205/55 R16) and it will calculate the appropriate tyre profile to use with a different wheel rim diameter (eg 18").
cheers
http://www.golfmk4.co.uk
Mk4 Cruise Control Installation Expert
Offline jblack
« Reply #2 on: 07 October 2003, 23:24 »
Cheers mate. :)
Offline S11EPS
  • No golfs here. Only a C63 mercedes
« Reply #3 on: 08 October 2003, 13:43 »
If you're running the standard 16" Montreal II's on 205/55/16's your 'rolling radius' is 1985.5mm
if you move to 18" rims I suggest you run with a 205/40/18, which will give you a rolling radius of 1951mm
This is about as close as you get, with a difference of approx 1.74% - which is naff all really.
The greatest leveller of them all - the Carousel
