Author Topic: AAAAAGGGGHHHH how do I get my bloody speedo cable out?  (Read 4312 times)
Offline stainesy
« on: 14 September 2012, 14:46 »
Ok I'm trying to change my worm drive to fix my flickering speedo but I can not for the life of me get the bloody speedo cable out of the gearbox.
Looks as tho somebody has tried before as the round metal thing has marks all round it. It's stuck propper.
How do I get it out?
Offline CanisLupus
Re: AAAAAGGGGHHHH how do I get my bloody speedo cable out?
« Reply #1 on: 14 September 2012, 14:49 »
Normally just wiggle and pull...but you don't want to pull to hard incase the gear comes off and drops into the gearbox...which is not fun to find. The only secruring was the screw, but you have removbed that already.
Offline Gambit
« Reply #2 on: 14 September 2012, 14:54 »
can you spin/tap with hammer n drift the securing tab round 90 degree's then use that to level it up? spray a load of wd40 in round it also and it'll eventually seep inbetween
Offline stainesy
« Reply #3 on: 14 September 2012, 15:05 »
yeah i dont want to pull on it. iv tried getting a think screwdriver under the lip and tapping it but it dont budge.
will have to spray the sh!t out of it with WD40 and see what happens.
whats on the other side of it?
Offline Gambit
« Reply #4 on: 14 September 2012, 15:13 »
this.
Offline Gambit
« Reply #5 on: 14 September 2012, 15:16 »
though yours look suspiciously different! infact im gonna take a stab in the dark and say your cable has been forced down through the hole & the cable doesnt actually have a collar on it.
that looks like the cog i can see in your pic - if that is the case then you just need to retract the cog through the hole and then get the correct cable and refit.
worst case, the plastic cog falls off into the gearbox and gets smashed up by the gearbox cogs. it will not jam or damage the box, and usually draining gearbox will remove all the bits floating about in the oil!
« Last Edit: 14 September 2012, 15:18 by Gambit »
Offline stainesy
« Reply #6 on: 14 September 2012, 15:37 »
Inside the hole in the pic there is a metal dish that the cable goes against. If I pull the cable the skeave pulls up but the cable stays in. So there is the metal dish there.
Offline stainesy
« Reply #7 on: 14 September 2012, 18:40 »
Anybody got a pic of the speedo cable hole in the gearbox without the speedo cable in it?
Offline Jimmyrallye
  • 20vt goodness
« Reply #8 on: 14 September 2012, 19:16 »
I recently changed mine and the cog fell of in box and started jammin up every now and then in 3rd!!! As gambit said looks like the whole speedo has been smashed in to the gearbox hole :(
Offline stainesy
« Reply #9 on: 14 September 2012, 20:46 »
do you mean it looks like somebody has put the speedo cable in with cog but no metal bowl? how would that work as the pointy part the cog ataches to is sor of part of the bowl.
there is a metl bowl in there but when i pull the cable the sleave pulls up.
would reall help if i can see what the hole looks like withouth the bowl and cable in it so i could tell but cant find a pic on google and quite a hard one to look for.
