Author Topic: CarPro Reload Sealant  (Read 2269 times)
Offline Schuey
« on: 13 September 2012, 21:41 »
Has anybody used this product or got any opinions on it?
I want to try it on Carbon Grey.
Thanks
Offline Dan J
Re: CarPro Reload Sealant
« Reply #1 on: 13 September 2012, 21:53 »
Been using it a while now, awesome product, very easy to apply and gives a very nice finish, beading is really good, haven't really tested its durabilty to any degree but it does last and makes cleaning the car a lot easier.
It can ghost up on you in warm weather but on cool panels it's a breeze to apply doing small areas at a time and using a very small amount of product.
Offline Schuey
« Reply #2 on: 13 September 2012, 22:05 »
Thanks for the reply.
At what point is it best to apply as I want durability as I'm hoping to do a pre-winter clean this weekend.
I will snow foam, wash, iron x, clay etc..... As normal.
After which I would usually polish, sealant and then Colli 915.
Using the reload would I scrap the Colli and my normal sealant?
Offline Dan J
« Reply #3 on: 13 September 2012, 23:14 »
What sealant are you currently using? You'll get around 3months durabilty from reload but it can be layered up which will extend it to a point. You can use on say a monthly basis through the winter after each wash.
Offline Schuey
« Reply #4 on: 13 September 2012, 23:26 »
I only have 2 sealants, AG Extra Gloss and PB EXP.
Offline Dan J
« Reply #5 on: 13 September 2012, 23:54 »
Tbh I'd just use reload on its own, it's a much better product for protection and durabilty up against the two products you've got. But you could layer up your 915 and use reload every month or two to bump up gloss and beading/sheeting after a wash.
Offline butler2.8i
« Reply #6 on: 13 September 2012, 23:55 »
I love Reload its a really easy prodct to use at gives a cracking finish, its lasted 3 month on my test mule which is a mates builders van, only gets washed when i get time and still beads like mental  :cool:
Offline Schuey
« Reply #7 on: 14 September 2012, 08:39 »
Thank you for the advice/info.
I'll get some pics once it's done.
