Author Topic: Anti roll bar bushes  (Read 969 times)
Offline km
« on: 12 September 2012, 17:51 »
I've ran into another problem  :embarrassed:.
As I was fitting the bush, I used a longer bolt to close the gap. As I went to remove it, it became stuck?
It's almost as if there's a nut stuck on the other end, it's loose and keeps spinning but is unable to pull out.
Advice please?
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Anti roll bar bushes
« Reply #1 on: 12 September 2012, 18:24 »
Front ARB I asumme...
You used a longer bolt just to wind it down a bit and then went to remove the longer bolt to re fit the original bolt, is that correct?
Umm....Give it a good spray with some WD40 and really pull on it while un screwing it perhaps, try and get something to lever on it to pull on it with!  :undecided:
Offline km
« Reply #2 on: 12 September 2012, 20:03 »
Yep correct.
Don't know how I can pull on it as well to be honest but I'll try again in a week or so when I can be bothered.
Just want to know why it's happened too!
