Author Topic: heaters dont work  (Read 1932 times)
Offline brettd2012
heaters dont work
« on: 12 September 2012, 10:52 »
as above my heaters dont work unless i hit a bump hard i have checked fuses  and all wires that i could find leading 2 the heaters wtf is goin on help plz
Offline MS1COYS
  • Alfie 'H' 10-09-11
Re: heaters dont work
« Reply #1 on: 12 September 2012, 20:27 »
Sorry bro can't help you out  :smiley:
292bhp / 287lbft
Offline Gambit
« Reply #2 on: 13 September 2012, 17:14 »
when you say the heaters dont work, do you mean the electric fan doesnt run? or it doesnt get hot
fan doesnt work its probably had water ingress and hence stiff. get a replacment unit to test
heaters dont give hot air, check for bypass valves and remove if nessecary, if that doesnt work then replace the heater matrix
Offline brettd2012
« Reply #3 on: 04 October 2012, 23:54 »
hi sorry took so long get bk on. i managed 2 get it workin by puttin motor on a switch i replaced motor swtches and the little resister under dash and still nothin unless i hit a bump hard then they would work thanks for the help
