Author Topic: Woodruff key help  (Read 1764 times)
Offline Tomonator1985
  • Low 'n' Slow
Woodruff key help
« on: 12 September 2012, 07:31 »
Woodruff key worn on kr 1.8 16v Garage recomends an engine rebuild or a brand new lump!
I've read you don't actually need to do either.
Hoping for some more options.
Thanks
*MK2 Golf GTI 16v Small Bumper*
Offline Gambit
Re: Woodruff key help
« Reply #1 on: 12 September 2012, 09:16 »
Ive seen instances where crank pulley and crank nose had two holes drilled through pulley at 90 degree either side of woodruff key and then into the crank nose, then two dowell pins entered to keep it all in place. Get a new crank bolt also if its the 12sided bolt as these are stretch bolts.
Ill see can i find the link about the dowell pins
edit: same idea as this
http://www.brick-yard.co.uk/forum/fixing-loose-jx-bottom-pulley_topic31849.html
« Last Edit: 12 September 2012, 10:11 by Gambit »
  • Low 'n' Slow
« Reply #2 on: 15 September 2012, 10:16 »
NICE!
all fixed with new pulley kit, plus crank filed down to fit better....hope it's fixed now!
« Last Edit: 15 September 2012, 10:18 by Tomonator1985 »
