Author Topic: golf vcds fuel trim bank 1 to rich?? hepl please befor i scrap it!!!  (Read 6311 times)
Offline bikemach
hi all got my engine management light on AGAIN!! had a faulty lamba buut changed that, know i have a coolant temp sensor fault, new one in the post, but what do the other errors mean and how do i fix them,
cheers.
here are 2 scans,
first one,
4 Faults Found:
16500 -  Engine Coolant Temp. Sensor (G62): Implausible Signal
        P0116 - 35-10 -   - - Intermittent
16521 -  Oxygen (Lambda) Sensor B1 S2: Signal too Low
        P0137 - 35-10 -   - - Intermittent
16556 -  Fuel Trim; Bank 1: System Too Rich
        P0172 - 35-00 -   -
16523 -  Oxygen (Lambda) Sensor B1 S2: Response too Slow
        P0139 - 35-00 -   -
second scan,
4 Faults Found:
        P0139 - 35-00 -   -
        P0137 - 35-00 -   -
        P0172 - 35-00 -   -
anyone have any ideas?
« Last Edit: 11 September 2012, 20:40 by bikemach »
Offline optispart
temp sensor causing over fuel rich fault should go away with new
 cts :cool:
mk4 monster starts here
Offline bikemach
hi thanks for the reply, what is cts? do you mean the green water temp sensor?,
changed it the other day but management light just came back on, gona do another scan today, will post results.
thanks
Offline bikemach
VCDS-Lite Version: Release 1.1
Saturday, 15 September 2012, 00:31:12:7422
Control Module Part Number: 06A 906 018 ED
  Component and/or Version: 2.0l R4/2V  MOTR HS V04
           Software Coding: 00031
            Work Shop Code: WSC 00028
                      VCID: 68A3275D1B7D
2 Faults Found:
        P0139 - 35-00 -   -
Offline optispart
cts Coolant Temp Sensor
Hmmm still throwing same fault definatley the correct CTS?
cleared the faults after install?
if so possible wiring fault?
Offline bikemach
yeah am starting to think it could be a faulty connector, noticed sometimes the temp needle dont seem to move after my drive to work (about 5 mile),
starting to annoy me now lol,
is there more than one semsor?
and where are they located please,
Offline Chris.
Daft but thermostat?
Click For Build Thread
Offline optispart
good point thermostats are known on 1.8t ill take a pic of cts mate just the one im sure
Offline bikemach
thanks, had a look at the new cts yesterday, seens the plug was not snapped into place propperly,
wd and snaped the tab down with a small scred driver, will have to wait a couple of days to see if my light comes back on,
but yeat could change the thermostat i suppose, never thought about that,
car is a standard 2.0 8 gti,
looking for a 1.8t if i can get one, the 2.0 8v gti dont feel like it should be a gti !!
will update in a couple of days or when and if light comes back on,
also i have a crash data removal tool and airbad fault code remover if anyone close to me needs to use one.
Offline optispart
where are you bud i could just do with that atm lol
