Author Topic: Megs G220 Pads which to use  (Read 2341 times)
Offline richw911
« on: 11 September 2012, 12:38 »
Im going to be using my G220 on a BMW soon ive not used it for a long time, I have bought the following pads
1 x Meguiar's Soft Buff Cutting Pad - Brown
1 x Meguiar's Soft Buff Polishing Pad - Yellow
1 x Meguiar's Soft Buff Finishing Pad - Black
Forgive my stuipid questions its been a while  :embarrassed:
Im going to be using poorboys SSR , the car has light swirl marks am i right in saying the yellow polishing pad will be fine for this? Im i right in thinking the brown will be a bit harsh?
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Megs G220 Pads which to use
« Reply #1 on: 11 September 2012, 14:59 »
Give it a test with the yellow, if it isn't up to the job then go for the brown.  :smiley:
I have only really ever used the yellow polishing pad on the mk4 and the dubs paintwork are pretty tough, not sure how tough compared to beemers though!  :undecided:
Offline Jimble
« Reply #2 on: 12 September 2012, 00:19 »
Give it a test with the yellow, if it isn't up to the job then go for the brown.  :)
I have only really ever used the yellow polishing pad on the mk4 and the dubs paintwork are pretty tough, not sure how tough compared to beemers though!  :-\
^This, as a rule of thumb always start with the least abrasive combination and assess the results before moving on to the next, for example:
Black pad--SSR1
Yellow pad--SSR1
Brown pad--SSR 1
Black pad--SSR 2
Yellow pad--SSR 2
Brown pad--SSR 2
Black pad--SSR 3
Yellow pad--SSR 3
Brown pad--SSR 3
But always bare in mind that if you use a very abrasive polish/compound that they can inflict their own damage to to surface which may require refining with a light cut on a finishing pad.
Note: I've never used Poorboys SSR but the above is a valid example for any polish pad combo (i think) ;D
Offline waxamomo
« Reply #3 on: 24 September 2012, 18:39 »
Good answer above, what SSR polishes do you have? They do 1, 2, 2.5, and 3?
