Author Topic: polo 6n top cups. Or anyone with shorter front mounts? *PICS ADDED*  (Read 2602 times)
Offline km
fitted my psi tuning poly top mounts, ordered polo top cups with it.
it seems that the polo top cups' diameter is a lot smaller than the original ones.
is anyone else running these? are there any solutions to it? the rubber has come off the cup as i've tried to tighten it too much..
« Last Edit: 11 September 2012, 18:20 by km »
Offline km
Re: polo 6n top cups. Or anyone with shorter front mounts?
« Reply #1 on: 11 September 2012, 18:17 »
Offline 1stevester1
Same as mine looks right
Offline km
There's a gap between the top cup and where it sits though? It rattles if it's too loose and I can't over tighten it as it'll get pulled through?! Are there no other shallow caps out there that have a larger circumference?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Bloody hell! I'll be sticking with my Supersport caps then
Offline Lewy
Aren't they supposed to be 9N mounts?
Offline km
Tell me more wazzzer!
I'm currently using standard caps, they're as high as a skyscraper.
Reckon I could source some supersport caps?
Offline jamie1989
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline km
I dont have an account.
I made one just to view posts, seems to have been deleted.
Any chance you can paste it over please  :kiss:
Offline km
Something isnt right here is the link from edition
http://www.edition38.com/forums/index.php?showtopic=452758&st=20&p=4721965&hl=polybush%20top%20mount&fromsearch=1&#entry4721965
seen the pictures, does look the same to me, only reason why you can see the gap in my pictures is because the rubber has been removed and therefore doesn't hide it!  :undecided:
