Author Topic: MOT Tomorrow  (Read 1231 times)
Offline tigerj360
MOT Tomorrow
« on: 10 September 2012, 17:37 »
Not looking forward to it!
Things I think it will fail on:
Airbag light on
wheel bolt missing, due to old one being sheered off in the hub
Money i have at the moment:
£0
:cry:
On a serious note can anyone back up my thoughts on thinking the above are failures
Offline itavaltalainen
Re: MOT Tomorrow
« Reply #1 on: 10 September 2012, 17:57 »
Airbag light, well without fault code reader difficult but with some luck it is just the plug under the seat! Just disconnect your battery for a few hours, then undo the airbag connector under seat etc and see if there is any corrosion - unplug and plug in a few times. After you've done this reconnect battery and see if the light is still on.
Wheel bolt.... and you're driving like that? I guess it's sheared because of over tightening, suppose you've lubed them and tightened like a gorilla :angry: just in case you have lubed them - NO lube on bolts or the hub!! EVER!!
Try to get it out go to VW buy a new bolt for 2£ and that should be that....
Offline Luke1981
Re: MOT Tomorrow
« Reply #2 on: 10 September 2012, 18:05 »
I always dread MOT date, I just check the basics and pray that everything else is ok!
Good luck
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: MOT Tomorrow
« Reply #3 on: 10 September 2012, 19:02 »
The garage should be able to help you with getting the bolt out...Then just replace it. Will probs get charged maybe an hour labour.
As for the light...black tape?  :lipsrsealed:
Offline 1stevester1
Re: MOT Tomorrow
« Reply #4 on: 10 September 2012, 19:06 »
A bolt missing is a failure :laugh: not heard of that one
Offline Chris.
Re: MOT Tomorrow
« Reply #5 on: 10 September 2012, 19:55 »
ONly a failure if the tester doesnt have to remove a wheel trim that covers the bolts.  Otherwise, alloys and he can see the bolt missing its a fail.
Airbag light isnt on the test yet I dont think, more than likely a advisory rather than a fail.
Click For Build Thread
Offline 1.8t.jim
Re: MOT Tomorrow
« Reply #6 on: 11 September 2012, 07:24 »
good luck ! hope all goes well, i dread MOT time aswell  :sad:
Offline Toby
  • Car - less
Re: MOT Tomorrow
« Reply #7 on: 11 September 2012, 08:11 »
Check the earths on top of the batery for the sir bag
Currently down under
Offline tigerj360
Re: MOT Tomorrow
« Reply #8 on: 11 September 2012, 15:28 »
Good news guys went straight through today!
Well happy/lucky and only had two advisories:
Rear passenger door wont open from the inside which i knew about and rear brake discs slightly corroded  :smiley:
Must have not spotted the wheel bolt missing  :laugh:
Will try this later, cheers mate!
Will try this too! The wheel bolt was down to the previous owner not myself, no idea how it happened but am looking into getting it fixed ASAP
