Author Topic: upgradin turbo 130 to 150 bhp  (Read 3862 times)
Offline james c
  • honda eater
Re: upgradin turbo 130 to 150 bhp
« Reply #10 on: 11 September 2012, 23:12 »
if i changed injectors , nd the oil feed goin in to the turbo ( not sure if they are the same )
ya getting rid of the kat was said to me before , would the exhuast pipes av to be bigger then standard or wud it make a difference
Offline MS1COYS
  • Alfie 'H' 10-09-11
« Reply #11 on: 11 September 2012, 23:19 »
hay i have a mark 4 golf ,GT TDI ,originally 130 bhp , now 195 ,upgraded intercooler (front mount with all new fabricated pipes nd fittings... boostin at 2.1 bar ,,  turbo blew yesterday  :sad:,
wud a 150 bhp turbo fit my car ?
Spiking at 31psi....holy sh!t! Was that an overboost due to a faulty part? I can't believe that's standard  :shocked:
292bhp / 287lbft
Offline james c
  • honda eater
« Reply #12 on: 11 September 2012, 23:34 »
haha dats wat every1 say ,til i show dem on the gauge , 2.1 bar every gear (six speed) around 40psi going threw the pipes , that y I couldn't use normal couplers , use hydrailic hosing for a lorry
all parts are perfect til sunday gone , as u seen turbo
Offline MS1COYS
« Reply #13 on: 11 September 2012, 23:38 »
Still doesn't seem right. If you can hold 31psi through the whole rev range in every gear, that's a car wrecker for sure  :lipsrsealed:  :grin:
292bhp / 287lbft
Offline james c
  • honda eater
« Reply #14 on: 11 September 2012, 23:44 »
it puzzles every1 until you go for a spin in it , vtec eat ur heart ou  :drool:, stuck to the seat ....its being lik dat for four year , original turbo , so i dont mind getting new turbo now  :grin:
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #15 on: 12 September 2012, 08:52 »
I'd suggest a new map, possibly a little tamer one.  :rolleyes:
You can get a miltek decat for example, which is 2.5" from the turbo to where it join the original exhaust which is 2.25" so you would need a reducer to fit it.
If you plan on changing injectors you might as well get some proper ones, ie bigger than the 150s! As it will be a costly job unless you can do it all your self!
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #16 on: 12 September 2012, 09:25 »
And stop putting "Dat" instead of the word "That" as it makes you sound about 11 years old  :grin:
« Last Edit: 12 September 2012, 09:27 by F17BAD »
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline james c
  • honda eater
« Reply #17 on: 12 September 2012, 10:29 »
 :drool:my bad mate !!!
you're starting to sound like a teacher ! :rolleyes:
Offline MS1COYS
« Reply #18 on: 12 September 2012, 11:00 »
your starting to sound like a teacher ! :rolleyes:
It's you are or you're  :grin: :wink:
292bhp / 287lbft
Offline F17BAD
« Reply #19 on: 12 September 2012, 18:05 »
 :grin: :grin: :grin: :grin:
