Author Topic: bit of a problem  (Read 1954 times)
Offline wheatobear
bit of a problem
« on: 09 September 2012, 21:55 »
i was driving today and went over a bit of a bump and as i did my car like died....didnt cut out but all gauges went down as if i turned it off but went back normal as the engine was still on....it has done it a couple of times but only wen i hit a big bump....
any ideas?
Offline murraymint
Re: bit of a problem
« Reply #1 on: 09 September 2012, 22:08 »
Avoid bumps?  :undecided:  :wink:
josh
Offline wheatobear
« Reply #2 on: 09 September 2012, 22:18 »
some are unavoidable....
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #3 on: 09 September 2012, 22:25 »
Loose electrical connection?
Offline itavaltalainen
« Reply #4 on: 09 September 2012, 22:25 »
my money would be on ignition switch in particular since lights/dials on the dash died in addition to engine.
second best bet is something's loose in your central electrics.
Offline madmanmart
« Reply #5 on: 09 September 2012, 22:32 »
Sounds like the crank sensor wires earthing
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
« Reply #6 on: 09 September 2012, 22:37 »
crank sensor wiring would not cause ALL gauges to go down as ignition is still on - you should still see temp and petrol level at least. hence my money is on ign switch or connection (central electrics)
Offline tweed
« Reply #7 on: 09 September 2012, 22:52 »
I agree
