Author Topic: Ecu changes.  (Read 1239 times)
Offline Paulc33
Ecu changes.
« on: 09 September 2012, 20:51 »
Little bit of info wanted.
I have a arz 1.8t golf and have been offered a remapped ecu from the same car and engine code.
Is it possible to plug it straight in and run on my car?
Or is it more complicated than that?
Offline barrym381
Re: Ecu changes.
« Reply #1 on: 09 September 2012, 20:55 »
why not just have a custom map done for your car  :smiley:
Offline Paulc33
Re: Ecu changes.
« Reply #2 on: 09 September 2012, 22:12 »
Cos the ecu is £50!! That's why I wanted to know if this is possible
Offline Reesy23
Re: Ecu changes.
« Reply #3 on: 10 September 2012, 13:21 »
As long as the ECU is de imobbilized, it should be fine.
Offline 212hpdazza
  • agu bigger ports
Re: Ecu changes.
« Reply #4 on: 10 September 2012, 13:52 »
if u can get the clocks and key then its just plug n play if not u will have to get the ecu coded to ur car
indi bolf agu
Offline topher
  • Administrator
  • fully functioning
Re: Ecu changes.
« Reply #5 on: 10 September 2012, 19:34 »
i cant remember if ARZ came with immo2 or immo3 clocks (probably both just to confuse things!)
if its immo2 then its a simple 30 second job with vagcom to adapt the ecu to your immobiliser. if its immo3 you'll need something like tacho or commander to retrieve SKCs because you'll have to program the keys again.
Offline Paulc33
Re: Ecu changes.
« Reply #6 on: 10 September 2012, 21:18 »
Can all of these be done by vw dealers? As I have a friend who works there...
Offline 212hpdazza
  • agu bigger ports
Re: Ecu changes.
« Reply #7 on: 10 September 2012, 21:21 »
aslong as vag tacho vag com
indi bolf agu
Offline Granta Gti
Re: Ecu changes.
« Reply #8 on: 10 September 2012, 21:48 »
ARZ is immo2 irrc.
Offline rio_gti
Re: Ecu changes.
« Reply #9 on: 10 September 2012, 23:27 »
