Golf mk4
Wazzzer
Battery going flat over night.
Topic: Battery going flat over night. (Read 1434 times)
thatwillis
09 September 2012, 15:52 »
Hi guys.
I've been over in befast for a month or so to come back to find the battery flat in my golf 1.8t AGU. I charged up the battery fitted it and left it over night. 10 hours later the battery was almost compleatly dead. I can't see any lights that have been left on or anything running that shouldnt be. Does anyone have any ideas what might be causing this?
Willis
Luke1981
Re: Battery going flat over night.
09 September 2012, 15:56 »
Take it to your local auto electrician to see if the alternator is putting enough amps back into the battery. If it is then it could just be a shagged battery.
MK IV GT TDI 150 PD / MKII CADDY SDI
iansabf
GTI forum regular
09 September 2012, 22:03 »
Try a new battery? Swap yours with some elses in the household as a trial? At least its a free check before taking it to a garage
james2
No scammers please.
09 September 2012, 22:58 »
Get a new battery.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Dalo Harkin
10 September 2012, 17:51 »
Use a voltmeter to check the battery first
second the alternator
failing that one of the two is knackered or you have a ground fault (changed anything recently?)
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
Wayne
Sir Postalot
11 September 2012, 13:54 »
Check for current drain on the battery, make sure everything is off and you will soon see if you have a problem, I had the same issue years ago and it was the boot light staying on.
thatwillis
Reply #6 on:
18 September 2012, 23:06 »
Ahh sorry for the late reply I havent had access to the internet. (should be a basic human right)
Good idea about just swaping batterys to see if it still drains or not. How would I go about checking for current drain?
Golf mk4
Wazzzer
