Author Topic: oil leak!  (Read 2278 times)
Offline search
oil leak!
« on: 09 September 2012, 14:58 »
sorry for not searching I'm on mobile and away for weekend, but iv realised where iv been parking over night there seems to be an oil patch on the ground! iv not had chance to check the dip stick yet. but was wondering what's the worse case scenario. I remember seeing leak repairs solutions are these worth buying or a waste of money. cheers guys
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
Re: oil leak!
« Reply #1 on: 09 September 2012, 15:10 »
Got one on my Mk4 - turns out i had a small leak from a small crack in the sump, rocker cover gasket needs doing, and sump plug washer needed re-newing :)
Mk4 Gti - Gone but not forgotten!
Offline search
Re: oil leak!
« Reply #2 on: 09 September 2012, 18:14 »
should I take it in to a garage to get it seen to?
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline leigh_harty
  • Audi AGU
Re: oil leak!
« Reply #3 on: 09 September 2012, 18:43 »
No, just trace the leak back to the source. Or give everything a clean the run the engine
Dont lose your dinosaur!
Offline Xtrhardcore
Re: oil leak!
« Reply #4 on: 09 September 2012, 20:32 »
+1 unless you can find a garage to do a free inspection with no obligation?
Offline search
Re: oil leak!
« Reply #5 on: 10 September 2012, 21:43 »
ok gave it all a clean etc! 99.9% sure the leak is from the drain plug on the sump! do i get a new washer then do a engine flush new oil and new washer? or do i change the pan still and new drain plug with washer? thanks
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline DCmk3
Re: oil leak!
« Reply #6 on: 10 September 2012, 21:59 »
If the pan is still in good condition there's no need to replace it.
If you're about due for an oil change, just drain the oil, clean the plug and put a new washer on it, put it back in and fillup with oil again.
« Last Edit: 10 September 2012, 22:00 by DCmk3 »
2014 Mk7 GTI - Littco L500
