Author Topic: warm-up regulator - was the cause!  (Read 1826 times)
Offline Deefadog
  • Mk2 16V (November 89)
« on: 07 July 2005, 08:22 »
I have found the culptit! of my revs dipping when cold
I disconnected the electrical connection for the warm-up regulator.
And she drove perfect, no dipping what so ever, the engine even seemed alot smoother and seemed to pull better in lower revs in higher gears!
So is it the warm-up regulator that's knackered? i thought that disconnecting the wires would not have an effect on the mechanical side of the warm-up regulator?
« Last Edit: 08 July 2005, 07:03 by deefadog »
Offline Gambit
Re: warm-up regulator - was the cause!
« Reply #1 on: 08 July 2005, 09:25 »
its only the little electrical element that's knackered. by running it disconnected it simply uses the engine block temp to warm itself up rather than the electrical element. so u wont lose any performance or anything like that
Offline Deefadog
« Reply #2 on: 08 July 2005, 10:54 »
So is it ok to leave it unplugged? or should i replace it?
And if it's knackered how would it cause all those problems like the revs dipping to 400rpm?
Offline Deefadog
« Reply #3 on: 11 July 2005, 11:50 »
Any ideas anyone?
Offline Gambit
« Reply #4 on: 11 July 2005, 13:04 »
leave it unplugged till you manage to find a 2nd hand one, and then just replace it. £25 2nd hand and only two bolts holding it onto the side of the block
wont cause any probs being unplugged.
Offline Deefadog
« Reply #5 on: 11 July 2005, 13:19 »
Cheers mate,
Regarding the two fuel lines going to it, just let the fuel drain out and then re-attach?, just afraid of an airlock or something (being over cautious again) :)
Offline Gambit
« Reply #6 on: 11 July 2005, 13:33 »
aye just unscrew them and let any petrol dribble out. no chance of airlocks or anything like that
also, check n see has the brass cap been drilled on the back of it. if it has then someone has been tinkering with the fuel pressure - the infamous warm up reg mod
Offline Deefadog
« Reply #7 on: 11 July 2005, 14:07 »
Thanks!
Offline Deefadog
« Reply #8 on: 18 July 2005, 15:22 »
Changed this today, made no real difference! :(
The brass cap had not been tinkered with!
I have heard that each WUR may have the pressure set up differently, do i need to adjust anything to compensate?
Offline monzablue16v
« Reply #9 on: 18 July 2005, 23:26 »
What What What another mod I don't know anything about! a good mod (factory recall) or bad mod (wonder what this does)
 :laugh: :laugh:
