Author Topic: Clocks Vacum pipe....  (Read 1984 times)
Blue MK2
« on: 05 October 2003, 21:43 »
I was reading an article on problems with the vacum pipe coming out of the rear of the clocks or something.
The other day i was wiring my sterio and accidently pulled the vacum pipe from behind the clocks. Is this easy to put back?
What problems occur if this is not fixed?
Offline modulater
Re:Clocks Vacum pipe....
« Reply #1 on: 05 October 2003, 23:55 »
I think the vacuum pipe is for the MPG reading on the MFA. my give you rough idle as your sucking a little air in.
Blue MK2
« Reply #2 on: 06 October 2003, 16:20 »
Sorted the problem now the MFA makes more sence.  ;D
