Author Topic: red oil lamp flashing and buzzer 1.8t AGU  (Read 5174 times)
Offline 1.8t.jim
Re: red oil lamp flashing and buzzer 1.8t AGU
« Reply #10 on: 09 September 2012, 10:03 »
i just think for the sake of £29 for the pump i might aswell just change the pump whilst im under the car, ive got the sensor and pump ordered now anyway might also change my sump as that looks in a sorry banged up state and it looks like its been patched a few times, i just hope i havent done any damage to my engine, i was literally around the corner from my house when oil light came on and i took it straight home and parked it up and checked oil (which was ok)  :sad: its a gd job i wasnt on a long run out, i would of definatly screwed my engine then  :sad: does anybody know if tghis sort of problem has damaged my engine ?
Offline dan2252
« Reply #11 on: 09 September 2012, 11:49 »
I still wouldn't bother with pump mate, my oil light came on at 120 when the pick up pipe blocked up sO you should be ok, Diped clutch in and slowed right down saved it I think haha wouldn't bother with sensor either, If your fitting non gen parts, I'd rather have a 10 year old genuine oil pump than a new non genuine, new sump, oil change new pick up pipe from vw about 10 quid is all I'd do
MK4 golf 1.8 turbo agu :)
Offline paultownsend
« Reply #12 on: 11 September 2012, 19:23 »
hi matey, its paul who bought the exhaust
as others have said, i wouldnt bother with the pump, it will be the pick up pipe. there about £14 from vw. get yourself the proper oil and filter from vw/tps too.
if you were to buy i pump, i would only buy from vw/tps. the orininal ones lasted 12 years....
Offline james2
  • No scammers please.
« Reply #13 on: 12 September 2012, 18:30 »
VW / Audi sludge problems
While the the 1.8T engines in Audi A4's, Audi TT, VW Passat, Jetta, Golf, New Bettle, are all very prone to sludge build-up, Audi/VW does not have an extended warranty for them from the factory. The factory warranty is 4 year/50,000 miles but it can be extended if purchased.
Although Audi/VW now has 10,000 mile service intervals, oil changes can be done between "services", and should be done if the vehicle is driven in heavy traffic, offroad, and non-highway use. Also, Audi/ VW will only warrant an engine if the customer has proof of all their oil changes. As of 2004 I belive all 1.8T engines must use synthetic oil.
So if you own one of these sludge-prone engines, what can you do? Obviously, Volkswagen Audi Group (VAG) states that you use only VW/Audi recommended oil. You should also keep up on your oil changes, making them more frequent if you drive hard or haul a lot of cargo. The most important thing for the VW or Audi owner is this: if the oil light comes on and beeps the high pitch beep that almost everyone ignores, pull over and shut the engine down immediately. Many VAG engines can be saved by this procedure. Have the vehicled towed to a VAG dealer. Their standard procedure is to inspect the cam bearings; if they're not scored, the oil pan will be removed and cleaned out and all the crankcase breather hoses and the oil pickup tube will be replaced. They'll do an oil pressure test with a mechanical gauge, and hopefully will also replace the turbo lines. Finally, the turbo will be checked for bearing free-play. The VAG turbos run really hot even with proper oil and coolant supply - that's why you need a good quality synthetic in them.
Read more: http://www.carbibles.com/engineoil_bible.html#ixzz26HGoOcuK
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
