Author Topic: Cheap Dampers  (Read 1714 times)
Offline jack.pe
Cheap Dampers
« on: 07 September 2012, 12:04 »
Guys,
The dampers on my 1991 GTi 8V seem shot to me. I don't want to spend a fortune on adjustables, what is the least I can get away with for some decent quality replacement dampers?
I have seen some Bilsteins at £100 a pair, surely these would be an improvement? or do you have other suggestions? I have also seen Konis at £200 a pair, are they significantly better?
Suggestions greatly appreciated... also is changing them fairly simple? just need to buy a spring compressor right?
Offline Gambit
Re: Cheap Dampers
« Reply #1 on: 07 September 2012, 14:11 »
eurocarparts bilsteins will do the job if looking cheapy. and use the 25% off voucher also
general rule of thumb is...the more they cost the better they are!
Re: Cheap Dampers
« Reply #2 on: 11 September 2012, 08:52 »
Or go for Sachs or Boge gas units, they are good quality
Offline vii-cks
Re: Cheap Dampers
« Reply #3 on: 12 September 2012, 13:58 »
I've used sach ones before no issues ass they are usually what come on most Volkswagen's from factory (like on my mk4).
But Bilsteins are often a good price at ECP. If not try VeeDubMachine, often have some good offers even though just German quality.
Offline JamesS
Re: Cheap Dampers
« Reply #4 on: 13 September 2012, 15:56 »
I have found with shocks it seems to be buy cheap, buy twice! I would save up for some good quality shocks unless its dangerously bad!
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
Offline Diamond Hell
  • Opinions я Us
Re: Cheap Dampers
« Reply #5 on: 14 September 2012, 15:38 »
I think there's a couple of sides to this:
1. Cheap autofactor struts to replace original dampers: fine
2. CHeap coilovers for those wanting to slam their car: not fine
Offline jack.pe
Re: Cheap Dampers
« Reply #6 on: 21 September 2012, 15:22 »
thanks Fellas...
I assume the originals are shot since the car is 20+ years old and has 82000 on the clock.. but I am not hugely familiar with MK2s so perhaps not? it feels like it has little damping on the move and when pushing it up and down at a standstill it seems to have little rebound. it is certainly not a must have, but if a significant improvement I will go for it..
