Golf mk2
Cost on replacing 2nd gear syncro advice please
Topic: Cost on replacing 2nd gear syncro advice please (Read 3676 times)
walchy01
06 September 2012, 20:12 »
Hi there
As per title, i am looking at replacing the gear syncro,i know it is not a cheap job as its the gearbox out, but how much we talking guys pleae?
Russ
walchy01
Re: Cost on replacing 2nd gear syncro advice please
11 September 2012, 16:36 »
Anyone
danny_p
Forum addict
11 September 2012, 21:50 »
its not a job i think anyone would give a price on i know i wouldn't figure on gearbox overhaul
problem is with mk2 boxes when you pull them apart you can find quite a lot of worn parts that really need doing whie its apart to avoid "since you issues"
so about £600 iiirc was the last price i saw for a recon box add to that a clutc and a couple of hours to ge it out and a coupplpe to put it back
all the VW's have gone bar 1.
Lewy
11 September 2012, 21:53 »
PM 'Hotgolf' on ClubGTi, he's in south Wales but is known as a bit of a demon with a box'.
Diamond Hell
Serious forum addict
Opinions я Us
12 September 2012, 20:05 »
Or just change the oil for some good quality stuff.
Gambit
Forum addict
12 September 2012, 21:59 »
Redline mtf and fitting a mk3 weighted shift rod will dampen down the crunch.
Wayne
Sir Postalot
Reply #6 on:
14 September 2012, 13:32 »
Better option in the long run is a recon box.
Mk2Kezza
Here all the time
Reply #7 on:
17 September 2012, 20:04 »
I had the 2nd gear synchro replaced when I swapped my 5th gear for a longer ratio one. Cost about £250-300. Was carried out by Andrew Lennox 01792 293483, based in Swansea. Quality job and the car is now on 235,000 miles and no 2nd gear crunch!
http://www.swanseavwspecialists.co.uk/home
Keri
<br />Almost finished.....
Golf mk2
