Author Topic: Clutch Slipping or Rubbers ?  (Read 2229 times)
Offline RedHP
« on: 06 September 2012, 18:23 »
Hi Boys and Girls,
Advice please - I am still running all fours on winter tyres which aren't very grippy unless temperature is below 5 degrees, so on full power my car can often slide even with TC on. But have now noticed that when applying full power after already reaching 30mph, the revs go higher than what the wheels are planting. But only but 400-600 on the revo. Considering that the weather is sunndy and roads are dry, is this my clutch slipping or is it due to my winters not being able to plant the remapped power....?
Thanks in advance
Red
Mk6 GiT since birth in 2010
YNWA
Y444GAR
Re: Clutch Slipping or Rubbers ?
« Reply #1 on: 06 September 2012, 21:20 »
Sounds like ur DMF has given in, How much miles on your car?
Offline mkviken
« Reply #2 on: 06 September 2012, 21:24 »
if the wheels were spinning the speedo would go up as well as the rpm.
if just the rpms are going up it sounds like the clutch is slipping
Golf GTI 7.5 230 white silver
Offline Ginge 35Edition
« Reply #3 on: 06 September 2012, 22:38 »
I had this on a Mondeo and it was the dual mass flywheel. Basically the spring between the two halves had too much slack in it. They replaced but after a lot of arguing I'd get it to the stealers ASAP.
Without being rude, do you ride the clutch? Even if you drive with ya foot rested on the clutch it can be enough for it to engage, at least that's what ford told me?
Offline simonpolly
« Reply #4 on: 07 September 2012, 11:51 »
At about 30 mph stick it in 6th gear and put your foot right down,if the revs race away the clutch is slipping.
Golfgti build quality is average at best.
Offline RedHP
« Reply #5 on: 07 September 2012, 14:06 »
My GiT has done 35k now
Yes just rpm's but usually only between 4th and 6th gear
I sometimes coast (with car in gear and clutch down)
Thanks for advice peeps
Red
YNWA
Offline dubber36
« Reply #6 on: 07 September 2012, 18:27 »
Why? Doing that uses fuel to keep the engine ticking over. Coasting in gear  uses no fuel what so ever.
