Author Topic: HELP!! White smoke pumping out of the back?  (Read 4394 times)
Offline rfn_hodgson
« on: 06 September 2012, 12:44 »
Right lads I've got white smoke pumping out of the back of the car looked in the engine bay and there's no smoke coming from there ??? Please help, needing to get back to camp on Sunday :(
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline Toby
  • Car - less
Re: HELP!! White smoke pumping out of the back?
« Reply #1 on: 06 September 2012, 12:52 »
Turbo  :undecided:
Currently down under
Offline jamie1989
« Reply #2 on: 06 September 2012, 12:57 »
White smoke is water or condensation.
Blue/black is oil burning
White smoke on idle or underboost?
My Bora usually idles with with smoke but has done since owning the car. Iv put it down to water or condensation up the exhuast.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline rfn_hodgson
« Reply #3 on: 06 September 2012, 14:04 »
Well I put in the oil catch can install this morning... Then after 20 miles it stared to smoke... I'm not under boosting, but it seems to happen when lifting off the throttle
Offline madhead1987
« Reply #4 on: 06 September 2012, 14:17 »
Have you got one of the pipes trapes from catch can ?? I have done tho and was cacking it :)
Offline rfn_hodgson
« Reply #5 on: 06 September 2012, 15:10 »
Tge pipe going from the T piece down to the L sHape pipe has a slight kink in it, could that cause this drama??
Offline 1.8t.jim
« Reply #6 on: 06 September 2012, 21:44 »
changing my turbo in my AGU because of this reason  :angry: mine takes about 15 mins of driving to stop the white smoke, ive had it checked over by a mechanic and its the turbo seals going apparently, so its giving me an excuse put a KO3s in   :tongue: but mine has been doing it a while now so it wil be fine just isnt running right :)
Offline cullygti
« Reply #7 on: 07 September 2012, 12:21 »
no a slight kink would not cause any problems like that mate mine as got a slight kink and as done since i fitted my catch can
when you take your foot off boost does it give a cloud of smoke if it does it could be your stem seals
Offline rfn_hodgson
« Reply #8 on: 10 September 2012, 16:43 »
Wellive put it back to the way it was befor and no smoke, not even a hint, think I'm just going to leave the catch can for now :(
Offline james2
  • No scammers please.
« Reply #9 on: 11 September 2012, 21:05 »
We dont need a catch can . Are intercoolers,or is it oilcooler does that.  :nerd: we just need a bolt in the bottom of the intercooler like a sump bolt.  :laugh:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
