Author Topic: FuseBox Maintenance  (Read 6823 times)
Offline GolfRich
Re: FuseBox Maintenance
« Reply #10 on: 06 September 2012, 14:56 »
Ahh i see, thanks.
Surely it would of been easier for VW to have used an easier system i.e relay 1 for position 1 etc?
« Last Edit: 06 September 2012, 15:00 by GolfRich »
Offline GolfRich
« Reply #11 on: 07 September 2012, 10:14 »
Had a bit of time this morning so looked at the rear of the fuse box and it seems the leads are in a completely different to the diagram.
I am tempted to remove all cables and replace as in the diagram.
Can someone confirm though that I am reading right and where the current red and green wires are connected (as in pic) it should be the 8 pin yellow block (on each side)?
Thanks,
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #12 on: 07 September 2012, 10:44 »
Thanks,
I wouldn't & besides you can't put them any other way....
Don't mess with what you don't understand!!
For More Info Click To See;
Offline GolfRich
« Reply #13 on: 07 September 2012, 16:10 »
Hi,
You're right.
I don't mean remove the actual leads though, just the blocks a reposition them in line with the diagram.
Offline vii-cks
« Reply #14 on: 12 September 2012, 13:55 »
I've got an issue on partners mk2 with clicky dash, doesn't seem to be anything else as checked everything else, does your needle not move correctly/smoothly on the speedo, you don't think it's a dash or speedo cable like I believe it to be?
