Author Topic: tapping noise  (Read 10623 times)
Offline andy06
tapping noise
« on: 05 September 2012, 22:31 »
iv got a tapping noise coming from the engine on my mk5 gti, it sounds bad! could it be the follower for the fuel pump?
Offline Poached
Re: tapping noise
« Reply #1 on: 06 September 2012, 18:35 »
Most likely your injectors, so nothing wrong :smiley:
See here: http://www.youtube.com/watch?v=Hg1lhTlSZwE
Does it sound similar?
If your still concerned post a video up if you can for everyone to listen to.
There are a variety of sounds coming from the engine so it can be hard to pin point, your alternator and associated pulleys will also contribute to noise.
« Last Edit: 06 September 2012, 19:24 by Poached »
Offline MS1COYS
  • Alfie 'H' 10-09-11
Re: tapping noise
« Reply #2 on: 06 September 2012, 23:13 »
Direct fuel injection probably. Mine sounds like a diesel  :cool:
Althought it could be cam belt and auto tensioner. Either way no biggie  :smiley:
292bhp / 287lbft
Offline andy06
Re: tapping noise
« Reply #3 on: 08 September 2012, 06:58 »
a bit i suppose but it dont make the noise when cold but its bad when up to temp..
Offline andy06
Re: tapping noise
« Reply #4 on: 08 September 2012, 07:02 »
hi mate my car is quiet when its cold but sounds bad when up to norm temp, i dont know much about them as i am new to vw ....
Offline MS1COYS
Re: tapping noise
« Reply #5 on: 08 September 2012, 08:42 »
Neither do I bro  :smiley: get it checked an independent VAG specialist.
292bhp / 287lbft
Offline Saint Steve
Re: tapping noise
« Reply #6 on: 10 September 2012, 07:49 »
If you engine code is AXX, could be the cam chain which is expensive and the reason why your engine is Tappity sounding.  :sad:
Offline Poached
Re: tapping noise
« Reply #7 on: 10 September 2012, 16:55 »
Can you post a video?
Offline MS1COYS
Re: tapping noise
« Reply #8 on: 23 February 2016, 20:24 »
Just in case this is of any relevance to anyone. I've searched a few topics and see that it has been mentioned the AXX engine code is chain driven, which apparently is fault prone. I'd just like to point out the AXX is belt driven and no problem at all.
292bhp / 287lbft
Offline xodia
Re: tapping noise
« Reply #9 on: 25 February 2016, 18:12 »
all TFSI engines have both a belt and a chain.
The exhaust cam has a belt, the exhaust cam and inlet cam are linked with a chain and a tensioner on the other side, with the hpfp
