Golf mk4
Wazzzer
Timing problem
Topic: Timing problem (Read 1391 times)
Xtrhardcore
Here all the time
Mk3 Gti 2.0 8v MoreDoor
Timing problem
05 September 2012, 12:46 »
Doing the cam belt and water pump on me golf,
Before I've even touched anything the can looks a tooth out,
What would be the symptoms Of a tooth out? And should I put it back I line?
Mk4 Gti - Gone but not forgotten!
barrym381
Forum addict
Re: Timing problem
05 September 2012, 13:09 »
had this on my s3 not long ago idle will be slightly rough an sometimes it would throw a code up a cam shaft pos sensor
Last Edit: 05 September 2012, 13:12 by barrym381
Xtrhardcore
Here all the time
Re: Timing problem
05 September 2012, 13:31 »
It does idle a bit funny time times but no codes.
But funny idle I mean it jolts sometimes?
barrym381
Forum addict
Re: Timing problem
05 September 2012, 14:03 »
mine was just a bit rough at tick-over
Xtrhardcore
Here all the time
Re: Timing problem
06 September 2012, 08:46 »
Spent all day yesterday trying to sort it out but it keeps juming back a tooth!
Chris.
Re: Timing problem
06 September 2012, 21:42 »
Which part jumps back?
Click For Build Thread
248bhp 278lbft R - Tech Powered 1.8T!! - Gone but NOT forgotton
Xtrhardcore
Here all the time
Re: Timing problem
Reply #6 on:
08 September 2012, 10:10 »
It was the cam shaft that kept rotating back but all sorted now, timing is spot on and rough idle is no longer! Banging!
harlemex
Re: Timing problem
Reply #7 on:
09 September 2012, 13:14 »
the banging might be your rear bushes.
Chris.
Re: Timing problem
Reply #8 on:
09 September 2012, 13:40 »
Was going to say, compensate by pulling cam pulley round a tooth with a spanner and it will jump back to TDC when tensioned.
Xtrhardcore
Here all the time
Re: Timing problem
Reply #9 on:
09 September 2012, 14:43 »
Exactly what we did mate, pulled it forward an extra tooth so when it jumped back we were spot on
Golf mk4
Wazzzer
Timing problem
