Author Topic: clutch cable bulkhead repair(measurement needed plz)  (Read 3070 times)
Offline razla
« on: 04 September 2012, 17:50 »
Well, the repair on the bulkhead that the last owner of my car done, has finally failed. He'd used a 50x50mm angle with a hole in for the cable, it was sloppy, the hole was the wrong size, the cable was rubbing on the angle, a right mess. The angle was 150mm long and the whole thing has pulled through the bulkhead :undecided: , I've already fab'd a new plate at work,in-fact, I made two. I plan sandwhich whats left of the bulkhaed after removing the crap.
 The only problem I have really is the where the hole centre should be for the cable to go through. Would someone be kind enough to get a measurement for me if they get i minute? the only measurement I need is from the underside of the bulkhead to the hole centre of the cable. I would really appreciate it, please help a fellow mk1'er.
Cheers, Andy. :cool:
Villa in Orlando, Florida, 10 mins from Disney! Pm me.
Offline razla
Re: clutch cable bulkhead repair(measurement needed plz)
« Reply #1 on: 05 September 2012, 22:52 »
Managed to fix the clutch today :wink: I didn't realise how bad it was until I drove her tonight. Fitted a new cable at the same time as the old one had been frayed a bit, silky smooth now. It's a different car all toghether.
Offline SoundillusioN
« Reply #2 on: 06 September 2012, 11:48 »
was meant to get back to you on this with measurements from my car, by the time I got home from work it was dark and I forgot, glad you got it sorted and it's all good now. :afro:
Offline chalky white
« Reply #3 on: 29 September 2012, 10:15 »
You can buy a repair plate off E bay.
