Author Topic: Mk2 E/Windows front  (Read 2001 times)
Offline billy_vw
Mk2 E/Windows front
« on: 04 September 2012, 13:16 »
Im looking at a 16v 5 door later on a J plate
Apparently both front windows don't work
How easy available are replacements? IE regulators or motors? if thats the issue
& how easy to change
Thanks
Billy
MK5 GT TDi
Offline Len
Re: Mk2 E/Windows front
« Reply #1 on: 04 September 2012, 13:41 »
 :rolleyes:
 :kiss:
www.sas.org.uk
www.the-ace.org.uk
Offline X4MGS
  • VAG Parts SNOB!!!
For More Info Click To See;
Offline billy_vw
« Reply #3 on: 04 September 2012, 18:34 »
where is the relay located?
MK5 GT TDi
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #4 on: 04 September 2012, 18:37 »
Above or Below the fusebox No24
Offline dubber36
« Reply #5 on: 05 September 2012, 11:14 »
Mine is on a clip on the back of the centre console.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #6 on: 05 September 2012, 11:19 »
Normally It's;
 :D :D :D :D :D
Offline JamesS
« Reply #7 on: 05 September 2012, 15:27 »
As well as the main fuse I would check this:
I put a full set of lecky windows in my 5 door when I was doing an engine conversion. I took all of the motors apart, checked and greased them before installing because I had heard they get crusty like this inside. One of them didn’t work so thought the motor was up the creek, I took it apart and magnets looked good and there was no play etc so wasn't convinced it was a gonner (it's a right hassle to put back together though!). I looked to see how much replacements are and thought chuff that, took it to a local old school HiFi repair man and he found that the resistor on the motor had burnt out, £5 later a new resistor had been soldered on and was as good as new!
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
