Author Topic: sounding rough in reverse :(  (Read 4284 times)
Offline kaine2010
Re: sounding rough in reverse :(
« Reply #10 on: 03 September 2012, 15:54 »
cheers for the info :) me thinks i should have to get a second hand one at this rate but we shall see :) thank you
Offline twotwofour
« Reply #11 on: 03 September 2012, 16:45 »
My reverse has just started making a noise too. Works perfect, doesn't jump out of gear but I'm getting a rubbing sound as if its the wheel balance weights just catching something. I've checked it all out and it's definitely gear related as the noise disappears when I dip the clutch. Have I lost a tooth an it's maybe just rubbing on it?
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
Offline GOLF-MK3-GTI
« Reply #12 on: 03 September 2012, 17:11 »
Could be sticky release bearing or thrust bearing..
Offline twotwofour
« Reply #13 on: 03 September 2012, 21:44 »
It had fresh  gear oil not long ago. Only 93k miles too
« Reply #14 on: 04 September 2012, 11:34 »
it does not make a difference if you have changed the gear oil to fresh gear oil, The release bearing is part of the clutch kit.
P.S, Does it make the noise when stationary and you dip the clutch in & out or whilst driving??
Offline vw_golf_nutter
« Reply #15 on: 04 September 2012, 11:46 »
my gearbox has a knackered reverse and if im reversing it still does it if i dip the clutch. if i take it out of gear whilst rolling back the noise goes away. does yours not make the noise then if you dip the clutch with it still in gear? if not then i would say its not gearbox.
Offline twotwofour
« Reply #16 on: 04 September 2012, 12:22 »
No noise when I dip the clutch and no noise when stationary.
I'm thinking now it's a clutch issue then, like you say a release bearing as it can be snatchy at times but I put that down to needing a new clutch cable. Funny how it's only making a noise in reverse though and it disappears when I dip the clutch.
Offline kaine2010
« Reply #17 on: 04 September 2012, 12:38 »
I think I'm having the same problem as when I dip the clutch the noise stops in reverse when I release the clutch it starts making the noise
« Reply #18 on: 04 September 2012, 13:47 »
You got gearbox reverse idler issue, Will need a new box at some point.
« Reply #19 on: 04 September 2012, 13:49 »
You've got the same problem, gearbox reverse idler issue, does it make a noise that sounds like flapping or tick, tick, tick??
