Author Topic: 1.8 t agu problem!!  (Read 1144 times)
Offline gti_boz
1.8 t agu problem!!
« on: 02 September 2012, 21:26 »
Right!! My agu is running k04-001, Saab reds 3 inch maf and tip, front mount, 3 inch turbo back and a forge 007 dv
Basically it usually whistles and dumps quite loud, but seem to have droped a little power and nearly all of the whistle and dumping noise had disapeared. Any ideas?
Sticky dv?
N75 valve?
Was thinking maybe boost leak but runs and ticks over fine!!
« Last Edit: 02 September 2012, 21:43 by gti_boz »
Offline gti_boz
Re: 1.8 t agu problem!!
« Reply #1 on: 03 September 2012, 12:21 »
Could a faulty actuator cause this?
Offline Chris.
« Reply #2 on: 03 September 2012, 19:27 »
It would cause a loss of boost?
Fuel pressures ok?  Weak pumps are common on stage 2 AGU/1.8T.
Click For Build Thread
Offline tmparry01
« Reply #3 on: 15 September 2012, 20:26 »
I had a sticking dump valve that would stick aftr sharp lifts and gear changes.... Loosing all loads of.. .. Re grease with moly and was solved...
Offline dub whore
« Reply #4 on: 16 September 2012, 11:35 »
I have similar set up and mine don't waste at all. Saying that I still have the spring in the dv for standard set up which won't help I'm guessing?
