Author Topic: High pitch whining turning lock-to-lock ... video inside  (Read 1293 times)
Offline NotMyName
I guess that it's not specific to a TDI engine, so i'll post it in the MK4 section.
Car is a 2002 1.9 TDI
The whining noise is much louder over the drivers side.
Any clues as to what the cause is?
Offline Steve_PD
Re: High pitch whining turning lock-to-lock ... video inside
« Reply #1 on: 02 September 2012, 20:12 »
99% sure its the alternator pulley. They seize causing the squeaking. When I had mine done they charged £45 for the pulley and an hour to fit.
Offline NotMyName
« Reply #2 on: 03 September 2012, 19:04 »
Cheers Steve. It's from around that area certainly.
Where's best place to buy one from?
Offline Steve_PD
« Reply #3 on: 03 September 2012, 19:25 »
Yes the alternator is there. Only place is VW and you need a special tool to get it off.
Offline Prawny
  • R-tech power!!!
« Reply #4 on: 03 September 2012, 19:38 »
If it's only doing it when you turn lock to lock, I'd say it'd be low power steering fluid
Offline DubAndDubber
« Reply #5 on: 04 September 2012, 21:20 »
or low screenwash?
Mk5 Golf Gti 06'
Offline Steve_PD
« Reply #6 on: 04 September 2012, 22:20 »
Eh? Please explain your thoughts behind that?
Its doing it when going lock to lock because you're putting the auxiliary belt under load. Soon it willl chirping when you pull away and at idle.
