Author Topic: agu knocking under load and misfire  (Read 1805 times)
Offline whiteshep
  • dubs never die neither does the dubber
« on: 02 September 2012, 17:18 »
Hi there im new to the forum and im impressed with what i see, just wondering if anyone could help with my problem on my golf it has started making a knocking noise under load. It has a misfire and i have changed the coil packs and put new plugs in and the problem remains. I had the car plugged in and came up with error code 00561 which is bringing me to the idea of lambda or maf, was just wondering if anyone had ever had this problem and if so what was the results. The golf is running standard and all oem equipment and it is an agu engine would be greatful for any help thanks Jay
Mk4 golf gti 1.8t agu lump
Keep an eye out for future mods
Offline richw911
Re: agu knocking under load and misfire
« Reply #1 on: 02 September 2012, 18:09 »
Possible Solutions
    Refuel Vehicle
    Check Fuel System Pressure
    Check Mass Air Flow Sensor (G70)
    Check Intake Air System and Exhaust System for Leaks
    Check Injection Quantity
    Check Injector(s)
Retrieved from "http://wiki.ross-tech.com/index.php/00561"
Is it missfiring on just one cylinder? number 3? see here http://www.golfgtiforum.co.uk/index.php?topic=206325.0
Offline whiteshep
« Reply #2 on: 02 September 2012, 18:57 »
hi rich thanks for the reply thats the exact symptons i bought a couple of coil packs and changed them around and still stayed on that cylinder so if thats the case i will fly up and get one in the morning and hope it works
Offline whiteshep
« Reply #3 on: 03 September 2012, 17:58 »
hi rich went to gsf and purchased a new module and car is still the same mate you got anymore ideas on this problem many thanks
Offline richw911
« Reply #4 on: 03 September 2012, 19:18 »
Take the module back for a refund - i take it you check the wiring to that coilpack?
Offline whiteshep
« Reply #5 on: 03 September 2012, 19:27 »
already have mate just dont know whats next thinking lambda or cat
