Author Topic: Idle Issues  (Read 1352 times)
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
Idle Issues
« on: 02 September 2012, 14:28 »
Hi guys,
Been having idle issue on my AGN for some time, decided to take some calls of action to sort it out. Whilst sitting there on idle i can feel the whole car jolt sometimes, when your looking at the engine itself you can see it move, and its quite violent.
I've had a flat spot between 5-6k rpm so etc etc - So port of call was first the MAF - Changed it for a genuine bosch MAF - Also cleaned the TB out yesterday with carb cleaner.
Flat sport has gone but engine jolting and slight missfiring is still there... No codes either.
Thought it was a blow in my exhaust at first but had a completely new system put on manifold back.
Any ideas?  :shocked:
Mk4 Gti - Gone but not forgotten!
Offline 1.8t.jim
Re: Idle Issues
« Reply #1 on: 02 September 2012, 18:12 »
lambda sensor perhaps? i had this problem but as soon as i cleaned out my TB it went now running smooth as anything when i bought my AGU the first thing i did was change the MAF,lambda sensor and full service and clean TB and also try running a decent bottle of injector cleaner through it? REDEX pehaps? hope this helps
Offline Xtrhardcore
Re: Idle Issues
« Reply #2 on: 02 September 2012, 18:52 »
Alright mate sweet,
I'll run some redex through tomorrow, would lambda throw up a code? It feels better with the clean tb and new maf but still not perfect.
Offline 1.8t.jim
Re: Idle Issues
« Reply #3 on: 02 September 2012, 19:47 »
i put a bottle threw my gti and it felt loads better :) and the lambda sensor doesnt always throw up a code without doing data logging on your engine, i got my lambda sensor from NTK for £70 and it made my car run a lot smoother with having a new lambda sensor :) hope you get sorted, and if all else fails you could try changing spark plugs see if that helps ?
Offline Nino
Re: Idle Issues
« Reply #4 on: 02 September 2012, 21:44 »
I have this with my AUM, however I only find i get this strange idel issue after giving it some and I have no idea why its doing it ether :(
Current - MK6 GTi Edition 35
Offline Xtrhardcore
Re: Idle Issues
« Reply #5 on: 03 September 2012, 09:44 »
Right new Bosch lambda, NGK sparks and 500ml of redex on its way!
I'll let you know what happens
Offline Dalo Harkin
Re: Idle Issues
« Reply #6 on: 03 September 2012, 12:21 »
Do you know if you have one or two lambdas  :undecided:
Offline 1.8t.jim
Re: Idle Issues
« Reply #7 on: 03 September 2012, 13:41 »
my AGU only has 1 lambda sensor :) 1998 model
Offline Xtrhardcore
Re: Idle Issues
« Reply #8 on: 03 September 2012, 17:46 »
Got one on my AGN :)
Offline 1.8t.jim
Re: Idle Issues
« Reply #9 on: 03 September 2012, 20:15 »
and the lambda sensor is just before the cat on the exhuast down pipe :) hope it all gets sorted for you mate
