Author Topic: cutting out!  (Read 6698 times)
Offline Luke1981
cutting out!
« on: 01 September 2012, 21:24 »
My gt Tdi 150 pd keeps cutting out periodically. I know the fuel pump is not connected to to the diagnostics. Am I correct in thinking it could either be a faulty fuel pump or relay?
Luke
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: cutting out!
« Reply #1 on: 01 September 2012, 21:28 »
Literally no idea  :lipsrsealed:  :undecided:
How is it cutting out? While driving? No fuel or just randomly shutting down totally?
Offline Luke1981
Re: cutting out!
« Reply #2 on: 01 September 2012, 21:59 »
It just randomly cuts out when driving! Only happens once on each journey.
Offline Phil Miller
Re: cutting out!
« Reply #3 on: 01 September 2012, 23:49 »
Could be a few things, main ecu fees relay or water in the ecu, although that's more a mk5 problem than mk4, I've check the ecu relay first and go from there, do you have VCDS? If you do when the engine cuts out before you do anything or even touch the key try to code read the engine ecu, if it's a relay fault it won't connect to it as it doesnt have power
Hope that helps
Offline Luke1981
Re: cutting out!
« Reply #4 on: 02 September 2012, 10:23 »
Thanks for the help. What is the number of the relay? Cheers
Offline Phil Miller
Re: cutting out!
« Reply #5 on: 02 September 2012, 10:39 »
without looking im not 100% think its 109 or 18, depends on the level of your car it will be in relay slot 4 or 8
Offline Luke1981
Re: cutting out!
« Reply #6 on: 02 September 2012, 11:28 »
109 rings a bell. Thanks again.
Offline Rhyso
Re: cutting out!
« Reply #7 on: 02 September 2012, 18:11 »
Could be a faulty injector loom
Offline Luke1981
Re: cutting out!
« Reply #8 on: 30 September 2012, 17:45 »
I had the diagnostics checked and there was no faults. I got the ecu relay replaced and the car ran fine.
When I started it today it cut out whilst driving. The weather has been raining and the last time it cut out a few weeks back it was raining also. Don't know if this is a coincidence.
Any further ideas what might be causing this? It only happens very periodically.
Thanks
Offline Rhyso
Re: cutting out!
« Reply #9 on: 30 September 2012, 18:19 »
See my post above
